Milodon still makes one (P/N 13700). Runs about $350, and I think it takes some machining of the front of the block. If you're going to do it, have it ready when you have your machining done.
Holeshot
Here's a quote from the MASTER amc engine builder:
"you have to watch them though because a lot of them that I have seen are made with the hub machined backwards,the oil slot that lines up with the cam is on the front of the hub,I don't know if they were all made this way but i've seen four now that were,you can put a slot on the back,no big deal,if it doesn't have the slot on the back the dist. gear has no oil feed"
And he was right - it was machined b/w and had no oil feed for the distributor!!!
