I am about to pull and go through my 78 CJ 304. It has noisy lifters as if low oil pressure. Previous owner said the cam went flat once and was replaced, and it runs flat now like it is flat again. The motor and Jeep only has 30K on them, I want to make sure I cover ALL the important steps of going through the 304 so I do not have oiling problems. I am going to add a Howell fuel injection set up as well (my budget doesn't cover an Edelbrock...yet).
I have built many motors, but want to make sure I cover all the 304 specials things. Oiling? Pistons? Compression? :-| The Jeep will see low RPM up to 4500-5000 RPM, nothing fancy needed, just rock solid reliable and no pooch as it is pulling 33's and 4:11's on the 3-speed.
Thanks,
Alan
