steveo135
Hi ! Has someone put an EFI on there AMC 360 Yet? I would like to buy one but not sure if they are an easy fit? Could anyone help.
Dusty
Which EFI what style, somewhere out there i have seen a mechanical EFI setup on an AMC.
As to the Edelbrock EFI i found after the install which is straight forward and then the tuning which is minimal and the hand held controller makes it a cake walk, mine runs great was easy to install and was an out of the box fit. Only complaint is i had a few fuel pump issues so my recommendation is take the addtional time and retrofit your fuel tank with an intank pump other than that enjoy.
There is Howel throttle body injection (basically GM but with a custom chip burned)
Someguys just use straight junkyard gm throttle body injection
Edelbrock has a Multi port fuel injection setup
i think there is a performance budget efi company out there still
And a at one time i saw a setup that somebody was working on where they took the mechanical FI off of a 70's big 400 ci+ mecedees engine and were trying to make it work (read lots of custom machining, it needs a gear drive installed like a distributor gear to drive it and then it needs room)
steveo135
Hi , Thanks for your reply, I was thinking of putting the edelbrock EFI on my 360 amc. Can it be put on without removing the engine? Is there a pick up that has to go on the fly wheel ? The thing im most worried about is if there is any mods to do for pick ups for the computer. Any info would be great
Dusty
Thier system is bolt on and very well equipt. no additional sensors. yes it can be installed without removal of the engine.
You have to drill the dristributor for the dist gear and pin.
I'll post more for you later i have to run right now to a meeting but it is the easiest setup i have ever installed for fuel injection very smooth once you get it dialed in which doesnt take long
