wizzard
anyone know where i can get gear drive for a 72 401? i know you loose horse power but, it sounds good
Milodon still makes one. They run about $350. I believe the part # is 13700. I also think it requires some holes to be drilled/tapped in the front of the block, so it's best done while the engine is out and apart.
wizzard
thanks for the info. i have to pull it out time for a rebuild.
