pitjeep
needed for cj7, want to go from manual to auto. also need everything to go from manual to auto on a 304. ( flywheel,driveshafts, etc.)
have a fresh t-18, will bolt up to a 304, includes bellhousing(304) ,advance adaptor for t-18-dana 300, clutch. this tranny has 3 runs on it before jeep parted out . 600.00
may consider trade for a very good tf999, bellhousing, driveshaft combo for a cj7
junkyard jim
You can get the trans from a full size 6 cyl Jeep. (many came with it after '80) Some were 999 and some were 727. 8 and 6 used the same bolt pattern on the trans and crank, so the flexplate will bolt up, BUT the balance is different. 360/304 are different too. 6 is zero balanced (internal).
