if you are going to push the 401 off the pier just push it a little father north to pa :?
what studs did you use and what guide plates did you use ?
it should be milled the thickness of the guide plate
if needed I know a machinst in NJ that knows AMC motors and races them he does all my work and is good at it
I have crower roller rockers on my 401 with the 6090 heads and still had to go with a .080 + longer push rod any time you change rockers or get heads done the push rod length should be checked to keep the rockers in the right place
myself I would of gone with crower - crane or harnld sharp rockers too many places list rockers for amc and they are close but not right
http://www.amcforums.com/cgi-bin/yabb/YaBB.cgi?board=eng;action=display;num=1116533621
http://www.amcforums.com/cgi-bin/yabb/YaBB.cgi?board=eng;action=display;num=1116510392
http://www.amcforums.com/cgi-bin/yabb/YaBB.cgi?board=eng;action=display;num=1118585115
http://www.amcforums.com/cgi-bin/yabb/YaBB.cgi?board=aven;action=display;num=1115854071
