HotJimmy
Got new TRW forged 10:1's installed in my 401. Got motor all buttoned up and running tonight, but only weird thing is it blows puff of black smoke on rapid acceleration. If i slowly rap up the motor there is no smoke. I drove it about 45 minutes tonight around the neighborhood (neighbors are pissed 8) ) Runs great, but smoke is really bothering me. Carb is a Holley 750 double pumper- maybe new adjustments? 290 duration cam TRW's, stock heads decked .030", air gap intake. I was thinking about bumping it up to an 850cfm vacuum secondary carb. What is the smoke!? :(:
HotJimmy
Also it doesn't seem to wrap up as fast as it did before with my stock dish .040 over pistons.
try running a higher octane
Black smoke is usually because of a rich condition (too much fuel). You may try smaller secondary jets or bringing in the secondaries at a little higher RPM. You may want to try something with a vacuum secondary, unless you're drag racing it. I think a 750 is plenty. A bigger carb might only make the problem worse.
Give it a chance to get the rings seated before getting too concerned. Rich is better than lean during break in.
HotJimmy
adjusted the carb today, black smoke mostly all better, but i have consistant problem with squashing the vave seals and burning oil on high rpm. My cam is over .500 lift, i forget the actual #, will i still have the problem with the edelbrock performer heads? I'm so fed up with replacing them that i'm ready to make the purchace.
