Seen these in a rag I got in the mail today...
Demon Carburation, a subsidiary of Barry Grant, Inc. is introducing a new range of truck carburators with cfm ratings from 525 to 850. Available in Road, Speed, or Mighty versions, the Demon Trucker performs inpressively both on and off the asphault, and behaves particularly well at high angles of roll or pitch making it ideally suited to rock crawling. All of the Trucker models are equipped with four-corner idle-metering circuits and a vacuum-secondary pod fitted with a quick-change spring to control the opening of the secondary throttle plates.
In addition, the Demon Trucker is equipped with:
- Single inlet for simple plumbing
- Side-hung float bowls and .110" spring-loaded needle and seat assemblies for better fuel control
- Custom check valves in the metering circuitry to prevent fuel siphoning when the vehicle is at extreme angles
- Custom crossover vent tube to help prevent fuel from leaking from the float bowls
- Manual or electric choke (on Road and Speed series)
- Tuning parts interchangeable with other makes
For complete information contact Demon Carburation at 1-706-864-8544 or visit their website: www.barrygrant.com (note: they have nothing on their site about these yet)
