<t><p>More info:<br/>
86 cj7 4.2<br/>
I was talking to a fellow jeeper and he said " If you don't like the Motorcraft ignition system you can change it" So I did some research and next think you know I now hav a HEI didtributor in my jeep. It works great except for two things the valves rattle on acceleration and when cranking the first revolution of the engine on the sounds like the battery is low. <br/>
Futher research tells me that it's in the vaccuum advance.<br/>
Does any one know about this or have info on hwo to cure it?<br/>
Timing is set at 9 Deg BTD<br/>
plugs are gapped at .045"<br/>
vaccuum advance is plugged.<br/>
86 - <br/>
I have an 85 4.2 with HEI, pretty much acts the same, first turn sounds bad only when it's cold. Then it catches and runs like a top, I'm around 10-11 BTDC, but she purrs nice ;-)</p>
<p>I'm also ported and polished, with Clifford intake/headers and Webber 38 ;-)<br/>
Pat</p></t>
