alex wrotedid you do a voltage check to make sure your alternator is charging?I think the 2 wires are just for the amp gauge on your dash but I could be wrong.Unplug the wires your worried about and see if the alternator is putting out more volts than with the wires hooked up.
the alternator isnt charging at all. The engine is from a donor waggy and put into a tube chasis offroader so I dont have the factory wiring harness and dont know where the heck the two wires on the side marked 1 and 2 go. Im leading to believe that is why my alt isnt charging. Im not sure if there is a signal wire or something to kick the alt on/off.
