'86CJ
New to this, so here we go.
I have a stock '86 jeep with
4.2/999 auto/ Dana 300/Dana 30/Dana 44
Want to swap to 727 torqueflite
Will it bolt up without major mods?
Will I have to modify drive shaft?
KEV
:-| Why? The 999 hes a lower 1st gear than the 727(2.74 vs 2.48 I think)
and it's shorter too.
You can swap it but you will need to run some lift in front as part of the pan will hit the front driveshaft....unless you have a clockingplate
rollen dean montoya
keep the 999. changing your current setup might not be worth the hassle.
anyways welcome aboard =D> :t:
'86CJ
Thanks for the reply's, I have a spare 999 at the rebuilders now, should be ready this week. I was told that the 904 is the same except lower first gear. Is this good info?
:-| I do believe it depends on what it came from.. Didnt the 904 with the AMC bellhousing share the same first gear with the 999's?
Lifted79CJ7
