AMC 360 LONG BLOCK GIVE-AWAY
Tickets $9.00 ea (no minimum)
We take paypal using AMCV8giveaway@yahoo.com for the payee or money orders to
Bulltear ind
30401 Neal ave
Lindstrom MN 55045
OR
Click here to buy ticket (S)
Specs
360 Block bored over .030 honed for moly rings with mains drilled .339
.030 cast pistons
resized rods
new wrist pins
new clevite 77 main bearings drilled .339 chamfered oiling holes
new clevite 77 rod bearings
new double roller timing chain
new Comp Cam 270 camshaft
new Heavy duty lifters
new heavy duty pushrods
new Brass freeze plugs
new AMC briteblock blue paint
new Bulltear EXTRA capacity oil pan 7qt.
new Bulltear oil pickup tube
new Bulltear external oil filter adaptor with oil cooler .5"
new Bulltear nickel coated timing cover
new Bulltear midplate and gears
new water pump
new dipstick and tube
Heads casting #0502
seasoned heads
hot tanked
resurfaced
new springs
new seals
new valve keepers
ACCESORIES
1 case of Bulltear's AMC-HD oil
new Bulltear alternator relocation kit
Options for the winner
New Bulltear cast aluminum valve covers
Edelbrock aluminum heads
Edelbrock MPFI
Edelbrock AIR-Gap
Any Edelbrock carb
exchange for any Comp Cam - except roller and those non AMC
Comp Cams roller rockers
Forged pistons Sealed Power
Total seal rings
*Options are only valid to the winner of the Bulltear AMC360 give-away and are optioned at Bulltear's invoice amount.
Shipping to anywhere in the lower 48 states is FREE any where else is winners cost minus $260 which Bulltear will pay.
One drawing will be done to decide winner and it will be a single entry for each try purchased in a bin style drawing held on September 3rd 2005. Motor ships October 14th or whatever is more convenient for the winner.
Tickets are $9.00 non-refundable ea (no minimum)
Bulltear ind
30401 Neal ave
Lindstrom MN 55045
We assemble the short block (crank, pistons, rods, bearings, freeze plugs)
Engine is shipped via Forward air in a crate.
