tufcj Most guys use a wrench that fits the tube snugly, then tap on the handle to seat the tube. Also be sure to install the dipstick in the tube before seating it, so you know it goes thru the hole in the pan baffle. If you don't, the tube can be mis-aligned, and you'll never get the dipstick in without pulling and re-doing it. Bob tufcj
kozzy kozzy wrote:-| DOES ANYONE KNOW HOW TO INSTALL A OIL DIP STICK TUBE IN A 304 WITH OUT WRECKING IT? KOZZY I will give that a try. thanks Kozzy
