TOPTRUCKBOB
I am I the process of fuel injecting a 304. I am useing a GM TBI setup, but I am not sure what distributor I will need to use to work with the TBI. I know "howell" makes a similar setup.Anybody know what dist they use?? Thanks, Bob
eight
I used the stock motorcraft duraspark. You have to tack weld the centriputal advance weights, and don't hook up a line for the vacuum advance. The electronic spark controll will take care of the timing. You have to splice the 2 colored wires to the harness. The black wire is a ground and I hear it's not necessary, but I grounded it anyway. If you hook the colored wires backwards, you'll get timing retard instead of advance, and just have to rehook them the other way.
If you have any other questions, don't hesitate to ask. There's a thread under my name title something like "infected 360 swap". Lots of info in there.
