I just posted this on the MSD tech board.
MC-We spoke about this yesterday...read the solution it may make you sick.
I recently rebuilt my '79 Jeep 304 v-8 with new edelbrock cam, edelbrock intake, edelbrock carb, msd6 ignition, msd tfi coil and original distributor. I purchased and installed the msd 8869 wiring adapter to connect the msd6 magnetic pick-up wires to the oem motorcraft(ford) distributor. When I fired the motor it ran poorly. Rough idle, timing was impossible to set, vacuum advance caused timing to become totally erratic, slight misses that seemed to move around the engine, etc. I managed to run-in my new cam at 2000 rpm, but it otherwise would not run.
I have chased all possible sources of the poor running conditions for three weeks. Thank god this isn't my daily driver!I have posted questions on four different forums trying to get a little help. I was about to tear my front end apart to inspect my timing set to make sure that I installed it correctly. There must be a mistake somewhere. Yesterday I thought I would look here again to find any clues. Someone had recently posted about his similar installation (and problems) on his ford motor with the same 8869 wiring adapter. He had found the wires to be reversed in the adapter. He switched them and it ran well. The msd tech appologized for poor quality control.
I went home last night, studied the wires from the msd6 through the adapter and into the distributor and couldn't find any obvious wiring reversals. I could not verify, however, the proper location of the adapter wires at the distributor end since they disappear into the waterproof (motorcraft) plug. I decided to try reversing the wires at the msd6 end of the adapter. I plugged it in, started the engine, twisted the distributor, and it settled right into a smooth proud idle. Wow! I fixed it; but by "fixing" the manufacturer's mistake...this really agrivated me! So either the polarity is reversed in the msd6 unit, or the adapter was built wrong.
I am glad it is now running properly...thanks MSD???
Greg
Florida
