Ok i finally got the MJ running, and pulled into the garage, went to change the Hydraulic line for the throw out bearing broke too due to rust. So the tranny needs to come out now.
I have a few options
change the throwout bearing, and put the peugeot back in Neutral 111!!!
Put an AX-15in that i have, just need a t-case for it
Put a t-18 in with the NP208 t-case for now eventually add a doubler of some sort
Put an AW4 in, and use the controller from http://www.awshifting.com/
These are listed from easiest/ Most cost effecitve to hardest.
What are your opinions
this will be used for street driving and mostly Trail beating
-Paul
