tufcj wroteI get 10-12" travel on each corner with 1.5" lift springs, shackle reverse, and SOA. I went to a local 4x4 shop that had a ramp, twisted it to the max, then crawled under with a tape measure and measured lengths at full compression and droop. I ordered shocks with about 2" more travel than I could measure. Haven't had any problem so far. I ended up with Rancho shocks P/N 9112 on all 4 corners.
There are no tables, because it varies so much with shock mount placement, spring rates, and travel limits due to binding.
Thanks Bob,
The H-7018's and 7024's I have are about 4" too short at max flex. Didn't want them to be the suspension limiter.
Pat
