radamx wrotethe main bolts on a AMC are 1/2 inch .The main bolts on a small block chevy are 7/16 .
I do use big block chevy studs in all of my engines.
Just checked out the ARP site to try and get some cross referencing nailed down but the catalog on their site is from 2003? and the specifications for the bolts are not listed. It is possible the vendor number I saw was for a big block 2 bolt chevy application as the first 3 sets of numbers for the part number are different but the last 4 are the same for the small journal SB. It makes more sense that the 2 bolt big blocks are the actual ones being sold by the vendors since they are 1/2" as you have noted and the stock AMC bolts are 1/2". My builder DID check a stock big block chevy main bolt on my 343 but he felt that it wouldnt thread down as far as a stock 343 bolt, in essence the big block chevy bolts are a wee bit shorter.
I am sctracthing my head as to why ARP would make AMC head bolts and Rod bolts but not the all important main cap bolts?? 111!!! #-o
