wolfe_man
I have a 401 to a TH400 with the BW QT transfercase. I took a look tonight (Just got vehicle) and noticed it is one of the ones without the low range unit on it. Does anyone know what the part# for the low range unit is/where to get one or what transfercase will bolt to the TH400 in place of the QuadraTrac Unit? Thanks,
J4GRAND
Post an ad in the wanted section. It is a simple bolt on low range and I'm sure there are a few out there. You'll also need to get a low range shift lever and linkage. The attachment spot for the lever will be on the inside of the tranny hump under the driver's seat. I may even have an extra lever/linkage lying around- as a matter of fact, I know I do.
wolfe_man
Thanks,
I guess its junkyard hopping for me then. I dont need the shifter setup since its not in the wagoneer anymore (in a 63 scout 80) so I'm going to have to make one.
