Automatic Overdrive Transmissions are long standing discussion over at the IFSJA's forum.
Different folks have approached installing a OD Tranny in a FSJ from several ways.
The same logic applies to AMC Go-Fast Cars.
Use a GM OD tranny, 700R4, 4L60 or 4L80.
This would require an expensive adapter to go between the engine and transmission.
Use a 42RH from behind a 4.0L Jeep.
This model OD Trannys have the AMC bell-housing bolt pattern the we need to mount to our AMC 360/401 V8.
The 42RH is basically a Chrysler A500 OD Tranny which is based on the TF904/999.
These trannys are light to medium duty transmissions and are weak in stock form.
BUT, these OD transmissions can be built to accept the HP output of a V8 but at a considerable cost.
One IFSJA member, Ristow, has taken a A518 OD tranny, a close cousin of the TF727,
cut the Mopar bellhousing off and is welding a AMC TF727 in its place.
Check out his posting and his progress:
My Overdrive Transmission Project
There is an on going debate about the idea of taking the rear half of a A518, which is the OD unit of this tranny and mate it to a TF727.
While is appears that it will bolt up, I do not know if it will work.
Some say positively not, some say maybe, some say, why not?
Some issues that will need to worked out with type of OD tranny swap in a FSJ would include:
Rear cross member mounting, stand alone computer for the modern trannys, TV cable or kickdown linkages,
both the transmission and transfercase shifters and speedometer connections.
Larger issues would be transfercase options, driveshafts lengths.
Purpose:
If you performing this swap to save $$$ at the pump, I serious doubt your ever recoup your investment of both time and money in the swap.
If you are performing this swap as a hobbits adventure, and solving all the technical issues are more important to you
than the time and money spend, then I say it is a worth while project
