When I replaced my rear main seal I saw that the crank bearings were severely worn--down to the copper or bronze material. Not good! :!:
I didn't do anything about it, but after about a week the rear main started leaking again. I'm guessing this is from crank thrust issues. There must be a bit of play down there.
Should I replace the bearings? My initail thought is that they will also quickly self-destruct like the originals because the crank is walking. I'm also guessing that the crank should be machined. What do you think?
I am planning on upgrading to a 360 in the next year or two, so a rebuild is not what I'm looking for. This Jeep is only driven on some of the weekends and occasionally to work (5 miles).
How tough is it to do this? I've never messed around with a bottom end (on a motor), but I have rebuilt a couple of three-speed manuals, and replaced several head gaskets along with other assorted mechanical work.....I know my way around a toolbox--I've just have'nt ran into this problem before now.
I think my Jeep drives me.................to :razz:
