jeepmonster wroteThe end links are big, one end has an eye bushing and a big bolt with a torx fitting that bolts to a bracket on the frame, the other end goes to the sway bar obviously and it has a small ball joint that goes through the sway bar end hole, the threaded end sticks through the sway bar and it has a nut on the end, "the ball joint" section of the end link wore out and popped out of the end link, the threaded end is stuck in the end of the sway (bar in the mounting hole). I removed the big section of the end link and the nut from the threaded end that goes through the sway bar. My question is do I need a puller or tie rod separator type "fork" to dislodge the end link section from the sway bar??
From what it sounds like (like a tire rod end?) either should do the trick. Try sticking a pickle fork in there and tapping at it. If it's a ball joint set up like it sounds, it should be a tapered shaft that is snugged up by the nut on the outside thread.
Do you have a Chiltons or Haynes that shows the assembly? Like I said, I don't know the new Jeeps - but I do have a Jeep dealer within walking distance of the office - I could go look...
