Bulltear part #626a is a oil filter relocation kit that replaces the entire oil filter adaptor eliminating the oil filter bypass but still utilizes the pressure relief valve. This kit uses the high flow high filtration common type filters instead of the cheap clogging type filters for AMC V8's. Expect better pressure and cleaner oil as well as the ease of placing your oil filter anywhere in the engine compartment you desire! Kit includes 2 hoses, 4 -8 line fittings, oil filter adaptor plate, oil filter mount, new oil pump gears, .007" gasket and a .0085" gasket, new polished plunger and a std. pressure spring.
$125.00 (without gears, gaskets, spring and plunger) $97.50
Bulltear part #626b is the same as 626a but utilizes a .625 I.D. hose instead of the .5" I.D. hose that comes with #626a
$147.00 (without gears, gaskets, spring and plunger) $118.50
Bulltear part #626c is the cooling addition to #626a with the addition of a oil cooler for a longer engine service life and cooler operation on and off road . Kit includes 2 hoses, 2 line fittings.
$43.00
