Look at this thread in the "how-to tech" area. It's on stroking a 401. Lots of good discussion on stroke, deck height, compression height, and pin placement, all which have to be calculated in any stroker motor.
http://www.bulltear.com/forum/viewtopic.php?t=1473
I've never done a stroker, but I think that since the 401 has a longer stroke, it uses a shorter rod, since the deck height on both blocks is the same. Using a longer 360 rod with the 401 stroke would put the piston up above the block at the top of the stroke.
