You MUST use the roll pins. They keep the cover positively aligned so the distributor drive gears mesh properly. Using the bolts alone may cause enough mis-alignment to make it eat the distributor gear.
You should be able to find the correct diameter roll pins at any full service hardware store if yours are missing.
