Ok, I just got a set or torch's with tanks and cart and everything. I have never owned my own set, and any i have used before have usually been set up by someone else.
If i remember correctly the output for acetylene should be set between 7 and 10 psi, while oxygens should be between 25-30.
I found these 2 links which seem pretty helpfull
http://www.deltaconne.com/Welding%20torch%20steel%20cutting%20methods.htm
http://www.mavcc.org/PDFFiles/ITACW/OxyITA.pdf
But my other question is, the tanks have some gas in them, when i open the tanks they the guages read 150psi. What is normal pressure for a full tank? What other tips does anyone have for me?
Thanks In advance
-Paul
attempting not to burn down my house
