fuzz401
blew out the o-ring on the oil filter 4x -I had the high pressure oil bypass spring in took that out every thing good there now -- then noticed the idel would hang right above idle for a second or 2 pulled the vac advance off the carb and it cleared it up then seen oil dripping from the balancer figured the seal was bad - got the balancer off and the seal came off with it spone in the timming cover :(: :smile: :(:
Fuzz...dangit! replace that spring asap and send me your addy I will send you another oil seal
rollen dean montoya
ouch! hope ya get it fixed soon
