Top fuel vs RC211v
Found some interesting figures in here, I pulled it from a bike board I frequent.
Revheads will love this
A lesson in acceleration:
First, some useful info:
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows at the Daytona 500.
* Under full throttle, a Top Fuel dragster engine consumes 1 1/2 gallons
of nitro methane per second; a fully loaded 747 consumes jet fuel at the
same rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the
flame front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric
water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of
an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2
way, the engine is dieseling from compression plus the glow of exhaust
valves at 1400 degrees F. The engine can only be shut down by cutting
the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up
in the affected cylinders and then explodes with sufficient force to
blow cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at
an average of over 4G's. In order to reach 200 mph well before
half-track, the launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed
reading this sentence.
* Top Fuel Engines turn approximately 540 revolutions from light to light!
This one confused Stan, but stop & ponder the fact that the engine is
only used for apx 4 to 5 seconds.
* Including the burnout the engine must only survive 900 revolutions
under load.
* The red-line is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew
worked for free, and for once NOTHING BLOWS UP, each run costs an
estimated $1,000.00 per second. The current Top Fuel dragster elapsed
time record is 4.441 seconds for the quarter mile (10/05/03, Tony
Schumacher). The top speed record is 333.00 mph (533 km/h) as measured over the last 66' of The run (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are riding the average $250,000 Honda MotoGP bike. Over a mile up
the road, a Top Fuel dragster is staged and ready to launch down a
quarter mile strip as you pass. You have the advantage of a flying
start. You run the RC211V hard up through the gears and blast across the
starting line and past the dragster at an honest 200 mph (293 ft/sec).
The 'tree' goes green for both of you at that moment. The dragster
launches and starts after you. You keep your wrist cranked hard, but
you hear an incredibly brutal whine that sears your eardrums and within
3 seconds the dragster catches and passes you. He beats you to the
finish line, a quarter mile away from where you just passed him. Think
about it, from a standing start, the dragster had spotted you 200 mph
and not only caught, but nearly blasted you off the road when he passed
you within a mere 1320 foot long race course.
Yup they have reached the point of extreme physics with those suckers are they fun to watch....its like a missle with a parachute :shock:
cj5 buggy
:shock:
rollen dean montoya
god i love the smell of burning nitromethane :mrgreen: it smells,
it smells like the winternationals at pomona :lo1l:
Yea, Cool... But I think they have reached the theoretical limits in top fuel not because the limits of machines or whatever.. But because the runs are so short now you damn near need an instant replay in slo-mo to see the race!
rollen dean montoya
wait until the funnycars go that fast. wait the almost go that fast now :shock:
Phil
:shock: DAYUMM those are some wild stats! :!:
Just makes me wanna yell SUNDAY SUNDAY SUNDAY!!!
rollen dean montoya
i can smell the burning nitro now :mrgreen: :lo1l:
Soylent_Green
I think the next big evolution in drag racing would be a longer track. Imagine how different the machines would be if they had to go 1/2 mile or even a whole mile! :-|
bigun
Ex girl friend told a friend of hers that if she wished she could come up with a perfume that smelled like burning nitro and tire smoke. She figured she would become rich. LOL I have seen the heads come off what am I saying i have had it happen just as the rail was in front of me!!! I was in Phoenix When Schumacher ran 330 during time trails it was a buetifull run the front wheels were just touching the track and the rear wheels had just a faint haze of smoke hanging over them. For those who don't know that haze tells you that he was on the point of loosing traction which generally means it is a very fast run.
