OK, first off I'm an idiot, so get over it. I've not ever dealt with axles at all. :oops:
I bought these on line from a guy in Upper Alabama. Advertised as Dana 44's from a late 80's Blazer. He had them under his CJ7 but was going to Rockwells and a 454 :shock:
Anyway, got'm, slid'm under the CJ and the rear perches matched up fine
The front was more difficult (as some of you may remember) due to the shackle reverse and outboarding issues with 3/8" frame plates - but the front is done and it LOOKS like a 44.
(mines cleaner, with a hi-steer though :oops: )
The rear however is round w/about a 10.5 ctr-ctr bolt pattern, 2-3/4 tubes and has 12 bolts in the cover, no C-clip, and 28 splines. The outter bearing end is a 4 bolt flange, with way different axle shafts than the AMC20. And this is supposed to be a Detroit with 4.56's. I'm having doubts on that too (Eaton?)!!!
Larger axle view
Click for a different view
It doesn't look like a Chevy 44??
The two rear shafts (old//spares)
No castings on the pumpkin or webs except the large N on top???
What the hell is it??? I've got to get parts and new front spare axles
Thanx
