roadgrime wroteI looked at the air gap but i seem to remember that its range is 2500-5500 and since this is a heavy 4x4 i want to get as much grunt in the low end as possible even if it means sacrificing some of the top end.
as for the CC i am currently trying to figure out what dish head I have (since i cant find numbers stamped anywhere) as I know the volume of the head will have alot to do with my CC. i will probably drop you a line as i begin to work through the numbers on what i should expect and start deciding on parts.
they say 2500-5500 but it works really well all across the board and as to low end grunt the 401 has plenty so you can deter a little from common practice and sneak a few extra RPMS and HP into the picture without really loosing much if any noticable low end torque and crawlability. Most of the guys in our AMC powered group of jeeps either run the R2B edelbrock intake or the Airgap with one outcast running the torker. I agree with the above statement the holley is not a good intake, its like applying SB chevy or ford engine build techniques to a Big block hemi or an AMC :mrgreen:. (im visualizing a cocktail straw and a regular milkshake straw that poor 401 will be wheazing by 3500) :mrgreen:
Mad dog is selling that TRW 9.8 forged piston engine rebuild kit for something like 750 i think thats what i saw for a price anyways, the machinework and balancing on mine was 1600 minus the heads which would have been in the 700 ballpark but if i had shopped it around probably could have found a better deal. I leaned towards the Howards cam .479 lift 292 duration 222@ .50" on a 114 lobe. have seen and riden in one other 401 built with this cam and it idled well crawled really well had a fairly flat torque curve, pulled hard though and was really street friendly and that was with 9.7:1 compression and it had that sound to it that let you know it wasnt stock. my compression ratio with aluminium heads is 10.17:1 and i am using that cam with fuel injection. that same cam in a 10:1 360 was too much almost a gutless wonder off idle in a trail rig that came alive too late.
Becareful with the 401 not to cut yourself off at the nuts, i like being able to spin up to 6000 rpm when i want to and still being able to idle over rocks, the 401 offers that versatility too many people dont build em to take advantage of thier full potential. It's a long winded motor so let her breath, amazingly enough the torque sticks around on the dyno in the low rpms even when you bump the stick up quite a bit.
I want to say another 401 combo that a friend of mine is running in his CJ5 crawler is a 280H comp stick with .480 lift with 108 lobe, might be the 270H but anyways with 9.8:1 compression, airgap and 750 holley off road carb and DUI distributor. T-18 dana 20 and 3.73's on 33's and it has no problem idling over and up anything the rubicon or Moab has had to offerand yet is an animal out on the road and the sand dunes. It has a mild lope and lets you know its mean but it doesnt effect it at on on the trail.
And for your choice in intakes, on guy in our group has run a torker intake for forever 3000-7000rpm intake or what ever it is on stock 360's and a stock 304 and that thing has never seemed to effect those engines in his rock crawler.
The point of this long post is AMC like to work differently than many people expect. keep that in mind while choosing parts and pieces.
happy trails
