the part BT makes, is for a factory replacement dana 20 adapter to TH400. I believe.
if you dont want to use the quadr-trac t-case I beleive you need a different th400 case. You could probably find out more info here
http://www.novak-adapt.com
as far as the flex plate I have one here, from a 360 and also a flex plate from a tf727 to a 360
-Paul
