rollbar
O.k. a while ago I posted the numbers of the compression test for my wife's 86' CJ & I said that there was 100lbs in each cylinder & I would do it again & update you all as to any changes.
Well here's the news, each cylinder has 148lbs & 50lbs of oil pressure , YAHOOOOOOOOO!
I did the test wrong, duh.
In order to get the correct compression check of the engine you have to HOLD the throttle ALL the way OPEN & crank it @ least three times.
Peach has good compression, LOL.
So there's the update & I'm happy about this one.
RollBar
