Sorry, all the prices I'm talking about are in Canuck Bucks.
So as it sits, last night was a whopping -47 C or -53 F. Working in the garage was less than comfortable. All my tools had frost on them and the block also had frost on it.
After warming the garage up I started on pulling the block apart. I got a drop sheet to catch all the extra oil and coolant when I turn the block over. But before I turned it over I noticed something on one of the pistons.....Took a better look, though it was a scoring mark. But how would a score mark be in the center of the piston? An old tooth brush a rag and some gas revealed something I've never seen.......................................
Does this mean these are 0.030" Over Pistons? I tried measuring the bore size and came up with 4.101? I could be wrong and measured it wrong or just can't read the caliper...it was like the second time I've used it in 2 years.
I turned the block over and proceeded to remove the oil pan.....this PO had used a cork gasket and RVT out of the wazoo! Using a putty knife and deadblow hammer it took me 1/2 hour to get that crapper off. Next I noticed this.
Am I off or is this another oiling type of mod? Or would it be used for balancing?
Soon after the pan was off I realized that the block had already been rebuilt. I found stamping all over the place.
What should be my next course of action? I need the block tanked and Magna Fluxed. Should I pull the pistons and crank or let an engine shop do that?
As things are now I'm stumped till the weather turns a little warmer and I have some answers.
