rogers803
I have to tow a 79 CJ with Quadratrac and the optional reduction unit under the seat. The CJ will be towed approximately 400 miles this weekend.
My question is whether it will be okay to tow it with a dolly (two wheels up, two down). I was told that all I needed to do was put tranny in neutral and disengage the reduction unit. What do you guys suggest? I know I would have to disconnect the driveshaft with a Dana 300, but am not very familiar with Quadratrac. It is not running right now, so taking it off the dolly and driving it around a few minutes is not an option.
Suggestions?
when towing with a automatic transmission you always want the T-case in neutral and the transmission in park. That help? :wink:
rollbar
& if U don't like that after U get the Jep on a dolly U can disco the rear driveshaft from the pinion & tie it up to the frame or take the whole thing off.
Just my 0.02,
RollBar
Penguin
For 400 miles I would do as rollbar said and pull the driveshaft.
Dusty
with Q trac you'll have to pull the rive shaft otherwise my understanding is even with it in neutral the tcase will try and turn the front driveline and burn itself up
