Which heads are you running? If you have 75 or newer heads with the bridged rockers, you need to have some machine work done to use roller rockers. Only Harland-Sharp makes a bolt-on replacement for the bridged rocker that requires no machining ( http://www.harlandsharp.com/bolton3.htm ).
Generally you need to have the rocker pedestal on the head machined down about .250", you need to add guide plates and hardened pushrods (same length as SBC), and you need to have the bolt holes enlarged from 5/16" to 7/16", and use Chevy style screw in studs.
You can use 70-74 heads that have the Chevy style rockers from the factory by just replacing the studs with a Chevy replacement.
I used Crane Gold rockers on my 390 AMX, a P/N specifically for AMC. I still had to use a pushrod .100" longer than stock to center the tip of the roller on the top of the valve.
