I swapped a 360 into a 64 American. You can use the the grem/spirit/concord... cross member. You will need to change the radiator, if using a turbo 400 you will probably have to custom build a trans x member, if you want the rear to last you will need to swap to a better rear end. Wiring will also have to be modified. Hope this info helps. email me at scottsds(AT)yahoo.com if you have any questions, or check out www.scottsamc.iniowa.org and go to my page about my American.
Scott
