pyagid
My j2000 has a 258 in it. It is a 1972 and has the old style exhaust and intake manifold.
Is there a benifit to the newer style? I am planning on putting a mc2100 on it. Will this bolt up the same way to the older style intake?
Also will a 258 header from a cj fit in the j2000 frame?
Thanks
Paul
thejeepingoat
i just took an intake and exhaust off my 84 258, you need it let me know and we can work something out.
pyagid
Sent you a PM.
mrtazwrench
some of theose old ones had a 232 in them, have this one i pulled from a 74, sat in the shed for years, a guy wanted it for a cj checked the numbers and it was a 232. :-|
pyagid
:-| This appears to have everything original on the truck still. The sticker on the inner fender says 258. I guess I will actually have to check the numbers though to be sure
-Paul
mrtazwrench
if the sticker says 258 you have good chances then. :t:
