I was told the expansion properties between the case/gears would be more equal than the sintered gears, and they would hold a more steady pressure thru the temp ranges
These guys selling these arent hip on metallurgy. If it isnt cast aluminum with the same amount of silicone then it doesnt share the same properties or co-efficient of thermal expansion as the timing cover. Also billet aluminum expands more than twice as fast as cast......Binding!!!
Mopar gears are crown gear and all gears including factory gears are only able to manage a certain amount of pressure on the from the oil pump. Using high flow gears only leads to distributor and cam gear destruction.
These guys selling a high flow oil pump gear set have no clue what is actually going on in the pump itself. If you took the the pressure bypass away you would blow off 100% of your oil filters...bloated and blown or blown out the rubber seal or strip the threads on the oil filters. The AMC oil pump isnt where the oiling issues are 100% of the time. You arnet the first person to have these issues. I was told that even the person promoting these kits is having massive distributor gear wear...this is caused by overpowered pump issues usually in the form of binding or when using high flow oil pump gears. We have done this tech years ago and because we couldnt offer a set of distributor gear and cam gear with the high flow oil pump we didnt offer it to the public. If you look through the oiling section here you will find the issues with the aluminum oil pump and high flow oil pump gear seats....they arent engineered to work with their driving components #-o
