MAKE AND YEAR C.I.D. LITRE BORE CYL. DESCRIPTION BLOCK CASTING NUMBER HEAD CASTING NUMBER CRANK CASTING NUMBER
AMC 1983-88 150 2.5 3.875 L-4 Eagle, 7/16" 3239448 3244893 3239611
AMC 1988-71 150 2.5 3.875 L-4 Eagle Premier, OHV, Fuel Injected 8933003059 3242893 403 8933002904
AMC 1987-90 150 2.5 3.875 L-4 Fuel Inj., 2.06" Crank Neck, 7/16" Head Bolts, Wrangler 8933004200 408 8933002904
AMC 1986-90 150 2.5 3.875 L-4 Carb., 1/2" Head Bolts, 2.06" Crank Neck, Wrangler 53005532 . 8933002904
AMC 1991-92 150 2.5 3.875 L-4 Fuel Injected, 7/16" Head Bolts, Wrangler 63008403 117 8933002904
AMC 1970-72 232 3.8 3.75 L-6 W/Rocker Shaft, Spec. Flat Back or Flanged Style Crank 3199962 3218618 3189886 3170717 3211040 3172216 3172218 3188947 3204904
AMC 1972-74 232 3.8 3.75 L-6 W/Rocker Shaft, Spec. Flat Back or Flanged Style Crank 3213867 3218618 3222380 3710717 3189886 3211040 3213809 3224490 3214722
AMC 1975-79 232 3.8 3.75 L-6 3224098 3227445 3227258 3241722
AMC 1987-90 241 4.0 3.875 L-6 53005535 8933002665 2686 3003453
AMC 1991-93 241 4.0 3.875 L-6 53008405 7120 3003453
AMC 1970-72 258 4.2 3.75 L-6 W/Rocker Shaft, Spec. Flat Back or Flanged Style Crank 3199962 3211040 3170717 3189886 3199798 RD67703
AMC 1970-72 258 4.2 3.75 L-6 W/Rocker Shaft 3218618 3222380 3213867 3211040 3170717 3214723
AMC 1975-79 258 4.2 3.75 L-6 Spec. Location of Temp. Send. Unit, 1/2" Head Bolts 3227445 3224098 3227258 3214723
AMC 1980 258 4.2 3.75 L-6 Temp. Send. Unit at Top Rear of Head 3235077 3227258 3214723
AMC 1981-85 258 4.2 3.75 L-6 7/16" Head Bolts 3235444 3933000 3224480 3241656 3235477
AMC 1986 258 4.2 3.75 L-6 1/2" Head Bolts 3235444 3933002 3235477
AMC 1987-89 258 4.2 3.75 L-6 2.06" Crank Neck, Spec. if Alum. or Plastic Valve Cover, 1/2" Head Bolts 3235444 3661 3727
AMC 1970-79 304 5.0 3.75 V-8 3195527 32129903218086 3233324 RD51261 4487237 3195292 3214724
AMC 1970-78 360 5.9 4.08 V-8 Spec. Stud Type or Bolt Down Rocker Cyl. Heads. Must Have Head Cast # 3195528 3196291 3220502 3231475 3216090 3219993 3233344 RD51261 4487237 3195292 3214724 3214754
AMC 1971-76 401 6.6 4.165 V-8 Spec. Stud Type or Bolt Down Rocker Cyl. Heads. Must Have Head Cast # 3198951 3196291 3219993 3216090 3220502 3231475 3190079 3196921 3214725 3220411 3199842
