wdwrlw My Haynes manual does not indicate all torque specs for my 80 CJ. From the Hubs into the Hog head they miss a few things. The only torque spec I am concerned about is the Differential (Carrier) Bearing retainer caps. There are 2 Bearing caps both with 2 bolts (9/16ths). What should be the Torque specs on a Bearing retainer cap? Thanks
Lifted79CJ7 Here's a great site to check out for axle tech: http://www.ringpinion.com/ Are you looking for the front or rear axle? Jack
