This is taken from my posts on another board and may help some builders here, let me know if I left anything out.
recipe for a 400hp 360
p.s. easy to do
360 bored over at least .030 (.060 if you dont mind block filler)
ported heads mostly behind the valves and enlarge teh ports to the intake and exhaust.
headers .....stock manifolds do not flow as well (some older AMC cars guys will argue this with the free flow manifolds.but its bs)
Valve train you will need springs in the 110-140 area for this buildup
Roller rockers (chevy rockers work {1.6 ratio} or harladn sharps although when your over 6500rpms the poly locks break) you will need guideplates for your pushrods and dont run guideplates without moly pushrods
Solid lifters (forget hydraulic they are a huge waste of power and energy) or Roller lifter (roller lifters are the top dog for building power but depending on the company you buy from you may need to have the lifter bores bored and sleeved)
Take your cam bearings and drill a .201 hole in them and use that hole for your oiling (every bearing but the front cam bearing {it feeds the dizzy gear})
drill out your mains to .339 {letter R or a 11/32 drill} make sure to drill out your bearings as well, we always do the last 4 bearings.
Cross drill that crank (400hp is alot on a butter crank like the 360 crank any more and you can cause over stress of the crank and major thrust bearing wear that can attribute to piston pin landing damage and un constant knock which also break rods and makes engine builders unhappy cause you just punched a hole in that block)
Camshaft..this is one of the most important things you will do. You must use a quality cam with a solid or roller rocker lifter. Comp cams 280 or 290 are great for this
Oil pump...do not build around a used oil pump, they are cheap enough today to replace when building an engine. Bulltear sells em cheap and so does performanceamstyle.com and a ton of others.
oil filter adaptor do not use a old adaptor without either plugging it (where the oil filter bypas is or replacing it with a new upgraded one with that area cast in (chrysler found out in the late 80's that this was a bad idea and suddenly the engines were lasting longer.
Deck height what is ideal is a zero deck height and a minimum of .042-.044 quench for rod stetch and crank twist between top of piston and head. We make copper head gasets in a .030 (this will not work with a zero deck height...you may need to run fel pro at .046 or ROL gaskets if you deck your block)
Intake...400hp is a fair amount and you wont get it with a stock 4bbl intake. You want at least a torker if not air gap R4B or a edelbrock MPFI. You can hit that mark pretty well with a cross ram but they require alot of carb and generally hit high hp in the higher rpm 5000-7500, tunnel ram can get you there as well as a blow through turbo or super charger
carb...dotn bother with a edelbrock 600cfm opt for the larger edelbrock or a large DP holley or a demon...predator carbs are great for rock climbing but can be bastard gas hogs as well.
piston compression ratio.....at least 10-1...343 pistons will give you 10.5 to 1 compression this may be too much with the decking for the stock cast rods.
Scat has new forged rods for the 360 coming fast so keep an eye out if you need these at Bulltear.com or fastengineparts.com
you want a good roller timing set and may want to balance the rotating assembly
under drive pulleys help we make those in 10 - 20 and 40 percent aluminum...shameless plug
the really hot spark is required as well as a very high breathing air cleaner...avoid the open top elemnt air cleaners they dont flow better than stock as they will cause air cavitation at the top of the carb. Closed elemnt dual snorkel is always best or a higher air cleaner to get cold air from the outside not warm air from the engine bay.
a dry sump oil pan may be needed if you expect very high rpm's we make a new upgraded sandwich plate that port matches your oil ports for better flow than the Milodon plate of yrs past...check out performanceamstyle.com for info on dry sumps and pans.
a good oil filter doesnt hurt either...avoid fram and instead purchase either Wix and napa gold. these filters are desinged to work with the engine and not a general filters all amterial like you will find in cheaper filters like fram.
when your building above 350 hp you dont want tight as nails crank tolerances you may want to stay around th middle of the tolerance for a strong hi hp motor
We also suggest for long term oiling modifications to your oil pump like this one, we explain the tech so you can hae this done yourself or we sell them done complete
Here is member brad arthur's nickle coated timing cover after eating 3 sets of gears. We found the height of the distributor gear to be wrong (not a cover defect) Normally one sets of roached gears will eat the oil pump up to the point of very low efficiency. The nickel not only protected the pump but the pump is still in spec after the nickel was chewed away and that is only a small amount but their is still sufficient nickel left over to give the pump many times longer service life than pumps without the nickel coating. Here is the proof
and here we see the oil filter adaptor with cosmetic scratching and a very small amount of nickle worn out, the nickel is just worn on the surface of the stock grooves and will still protect the pump for may many years.
here are pics on the sandwich adaptor
- Port matched for superior oil control and flow
- hole size opened up for better oiling and less restriction
- Billet aluminum
- more material on the tapped holes allows for ZERO restiction caused by over tightening fittings
- gasket matched
- available soon with various thickness of gaskets and in different coatings
- superior oiling angles when compared to all aftermarket pieces
Only avaible at Performanceamstyle.com for 6 months
More Pro part Line up coming soon
and pics of a block that has been bored from the mains...do not bore with cam bearings installed!!!!
With the help of Frank in norways website
Lets stay on track and do a little learning between wheelers here. I may have gone overbored and that combo I listed may hit the 450-475hp mark...oops. Here is the combo listed from a amc 360 for the dyno below, if the pic doesnt come up please click the link
AMC 360 bored .30 over
Stock crankshaft .10 under
Cast pistons 9:1 comp.
Stock rockers
2.02 int./1.68 ext valves
PAW camshaft 214/224 @050
Chevy chrome-moly push rods
Edelbrock Performer Manifold
Holley 600 carb.
K&N 14x5" Air Filter
Jacobs Ultra-Team ignition
BlackJack headers
Custom 2 1/2" dual exhaust
http://www.fullsizejeep.com/1024/pics/drivetrain/dyno3.jpg
Well, I have not had the chance to do an actual dyno test. I did however do several computer simulated test that showed me a peak Hp of 364 at 5500rpm and a peak torque of 400 at 4000 rpm. The torque was 361 at 2000rpm. This is the bare engine so I suspect different numbers at the wheels :-)) I also simulated a run down the 1/4 and ended at 13.91/102.3mph with my 35" mudders. I suppose the day I'll try the Wagoneer on the strip will never come, but it's nice to know :-))
And the original 360 and the rebuilt one on the dyno
http://www.fullsizejeep.com/1024/pics/drivetrain/dycompare.jpg
