FrankNB wroteEver since my TFI upgrade I notice a great deal of noise in my CB(i.e. engine rpm).. How do you troubleshoot this kind of electric interference or whatever the real name of it is? Is there something to cure this?
I assume it's RPM related. If that's true I'd start looking at the plug wires, plugs, coil and distributor. Each of these can cause RFI to be eminated...Of course you've boosted the voltage to the plugs using the TFI upgrade. Now you need to contain it... in the wiring and plugs. If you did not change your plug wires then that's where I'd start. A good upgrade to Resistive wiring and resistor plugs may help and the cost is not too bad.
