mulescj8
So You Want To Be A Big Dog?
Ok guys this is going to be long and for a limited time before i change my freakin mind................so here goes:
1-One rear Dynatrac dana 60 axle,detriot locker,5:13 gears,rear disc brakes,35 spline axles,1 1/2" shafts with stock CJ bolt pattern(5 0n 5 1/2) bolt pattern,metal fussion diff gaurds.($120.00 New).........set up for SOA and will bolt into any scrambler or CJ from 81 to 86,inclundes rear CV (long travel) driveshaft 1310 U-Joints built by Tom Woods over $250.00 new.Includes brake lines
2-One front Dynatrac dana60 axle,detriot locker,5:13 gears,disc brakes,35 spline inner shafts and 35 spline stub shafts,1 1/2" shafts inner and outers,metal fussion diff gaurd($120.00 new)........Set up for SOA and will bolt into any CJ from 81 to 86,inclundes front long travel (11") driveshaft over $275.00 new.Stock 5 on 5 1/2 bolt pattern.Includes brake lines.Both axles are built to widetrack specs and have 1 1/4" Wheel spacers with them.
3-Dana 300 transfercase set up with 4to1 gears and twinstick shifters(gears are over $800.00 alone,not including labor,twin sticks are another $120.00 alone)
4-NV4500 tranny(over $2500.00 new with adapter) with shifter
5-258 motor(9000 miles on the Jasper built motor) with clifford intake and clifford header (header and intake alone are over $500.00 new.........with Howell TBI injection complete with manual(this is about $1100.00 new) not Calif legal.
6-3 core radiator and AGR steering box(no pump...I toasted it.Power steering lines included.
If you had these axles built today they would run $10,000 alone........I just priced a set for a friend.........So here is the deal everything is my Jeep right now and running,motor,transmission,and transfercase will be pulled as a unit..............so just bolt all this under your junk and throw on some 35" to 40" tires and go abuse it as much as you want.What does it cost to play with the "BIG DOGS" If you jump on this combo now it will save you "TONS" of money..........the whole combo and package can be yours for $11,500.00........this a proven system and it works...........been on the toughest trails in the midwest and east and has survied without breakage.......this price does not include the years or R&D i have put into this
system.So jump on it now before i change my mind.I would pefer to sell this as a package than part it out,if i do part it out i'll let everyone know-JC #-o
pyagid
:!: I wish i had money :smile:
Lifted79CJ7
JC, why don't you return the favor and hold some raffles?!?!? :wink:
mulescj8
OK will do! Tickets are $10,000.00 a piece.............PM me and i'll tell you were to send your money-lol-JC :mrgreen:
Lifted79CJ7
OK, so what in the world are you going to put in the 8 now? 401 for the engine.... ???for the tranny......??? for the tcase, and ???? for the axles.
I am gonna guess and auto, atlas, and 2.5 ton axles?
Jack
mulescj8
Close...........But i got to sell this stuff first if i don't change my mine......I just don't want the headache off pulling it all out and piece milling this stuff out to 14 differant buyers over 6 months time........if i find a buyer i'll just sell it all and then he can deal with selling what he don't want.........Ok plan is if i sell all this is: 401,auto tranny.atlas,and unimog 404 portal axles with 42" TSLs or 44" boggers :-| :t: :?
mulescj8
parting it out
ok i've decided to part some of this stuff out:
Front dynatrac Dana 60 with detriot locker with disc brakes,35 spine axles inner and outer,1 1/2" shafts,includes front brake stainless lines,5 on 5 1/2" bolt pattern will accept 15" wheels,high steer set up,1 ton chromolly drag link and tierod from rockstomper and JB heavy duty pitman arm($120.00 new) 1 1/4" wheel spacers for all four corners,these are forged and machine and not cast, 2 front long travel driveshafts by Tom Woods
Rear dynatrac Dana 60 with detriot locker,with rear disc brakes,35 spline 1 1/2" shafts,Stainless rear brake line,two rear Tom Woods CV driveshafts,with CV yoke for Dana 300 transfercase,all u-bolts and plates,1 full set of(4) used rancho 9000 shocks,all set up and ready to bolt in any CJ or Scrambler in SOA.
4-Alliled 15"x10",32 bolt beadlocks and a standard steel wheel for a spare.Priced new would be over 10k
sale for $7500.00-JC
As far as the motor goes,here are the specs on it.
Jasper Motor with appox 9000 miles on it,alum. valve cover,clifford header and intake,flow cooler water pump,even throw in the radiator,DUI distributor,
I'll take $700.00 for this set up if you want the howell TBI set up with it also then i'll take $1200.00 for the motor and TBI setup-JC
will consider offers,but be serious about it,this stuff is not cheap and i will not respone to to an offer of $2500.00 for something i'm asking $7500.00 for-I'll keep it and try to break it for that-I'm keeping the NV4500 and Transfercase- :wink: JC :t:
mulescj8
Everything is SOLD except the 258 motor and 5 Superswamper TSL's 39.5x15x15 4 are 80% tread and 1 is brandnew-JC
Briteblock
How much for the TSL's
