cblood
I just put on some 35's on my 76 cj 5, but the are rubbing a bit. I am planning on going SOA, but a quick fix is going to be a body lift. Now which body lift would be the best., and how much will work??
Lifted79CJ7
What kind of suspension are you running currenty and what type tires? Boggers? BFG Muds? What offset rim are you using?
Jack
cblood
Currently I have a 4" lift with Super Swamper TSL / SX 35 / 15.5. With 15x10 wheels with 2" of BS. I had to take the fender flares off yester day because of MAJOR rubbing, but today i took her out to see if the problem was resolved, bent my fender out. So I need a quick fix before I do the SOA. Looking for a good body lift.
Lifted79CJ7
You should be fine with a 1" body lift and resetting the bump stops.
