77 CJ7 with strong running 304 V8, T150 tranny. Rust bucket body and frame is shot. That’s why I am offering the complete rolling chassis 85 CJ7 wide track frame with it. Frame is painted and has Spring Over conversion minus welding the spring perches that you need to match up for your installation. All new u-bolts and perches, one brand new axle in the rear, Prothane bushings installed, all brakes work. The 77 CJ7 has a strong running 304 with power steering. Running gear is all good. Trans case mounting plate is bad but I have a new one on the 85 frame. The transfer case only goes into 4WH even when shifted into 4WL. I was told it is some shift fork. All you need to do transplant the motor and tranny on the 85 frame, drop a YJ body on it and off you go. No gauges in the CJ. Good front and rear lights, tailgate is very good other than a small ding (no rust on it). I don’t think any of the other body parts is useable. I use this guy to haul yard trash out to the road for pickup. The CJ7 also has Warn hubs. $1000 firm for all of it. Located near Melbourne FL.
Here's the CJ7
Here's the 85 CJ7 chassis
