Soylent_Green wroteI was told that a TF727 has the same case as the trans that jeep used in these things. Is this true? If so, couldn't I swap one of those in and have a much stronger trans? (minus O.D)
I know that Chrysler did make an overdrive version of the 727, but not sure if it uses the same type case or not. I know that the pan is deeper, a good candidate to swap into a TF727 vehicle for extra oil capacity. The regular 727 will mate up with the 4.0, but I believe you will need a tranny to tcase adapter for it. OK, I just looked it up. That thing has a 42RE transmission.
http://www.jeeptech.com/wiki/index.php/Transmission/Factory
http://www.jeeptech.com/wiki/index.php/Transmission/Conversion/TF727
Hope this helps,
Jack
