jeepsr4ever wroteOur entire line up of dress parts can also be engraved with 232-258 CID or 4.0ltr. This includes but is not limited to
Single and Twin stick shifter handles
Air cleaner nuts
Phenolic and non phenolic carb spacers
Keychains
Aluminum pulleys
:-| :-| :-| Only ONE of five of the above are listed on your retail page of 17 items ... :oops: :smile:
Part no: Description: Price:
1 ENG-AMC-613 Designed for high torque engines $43.99 / case of 12qts.
- Advanced friction protection
- Conditions seals
- High TBN (total base number)
- Double your oil change intervals safely
2 ENG-AMC-600 Made from billet 6061 Aluminum $17.25 ea
Triple chromed for maximum corrosion resistance
Replaces Iron wing nut on air cleaner
Deep 1/4-20 tapped hole for carb stud
3 ENG-AMC-601 Made from billet 6061 Aluminum $17.25 ea
4 ENG-AMC-602 Made from billet 6061 Aluminum $17.25 ea
5 ENG-AMC-603 Made from billet 6061 Aluminum $17.25 ea
6 ENG-AMC-604 Made out of 304 stainless steel $47.00 EA
Replaces factory plastic cold air vent on body 79-86 cj
7 ENG-AMC-605 Replaces Factory Timing cover/Oil pump $209.99 EA.
Inspected by Bulltear staff and guaranteed
within spec (no more bad replacements)
Fits AMC V8 67-91
8 ENG-AMC-612 Nickle plated for maximum abrasion $325.00 EA.
resistance in oil pump.
Kit comes with new hand lapped gears, .
0085 gasket high/Lox pressure springs and new plunger!
Please allow up to 10 working days for processing.
Fits AMC V8 67-91
9 ENG-AMC-606 33% over stock for AMC V8 oil pumps $12.50 ea
Easy installation
10 EMG-AMC-607 Fits AMC V8 67-91 $22.00 EA.
Stainless steel tube direct replacement for iron oil fill tube
11 ENG-AMC-608 Oil pump kit AMC V8 $36.00 ea
Premium Hand lapped gears
Kit comes with High and Low pressure springs
Kit also includes premium .0085 gasket and new plunger
12 ENG-AMC-610 AMC V8 oil pump midplate $89.99 ea
Tough 304 stainles steel midplate sandwiches between timing cover and oil filter adaptor. Increases oil pump life! Midplate Kit comes with port matched 304 stainless steel plate, longer stainless steel socket head capscrews, permatex indianhead shellac. Fits AMC V8 67-91. *please allow up to 10 business days for processing
13 ENG-ACC-700 Shift handle made from a solid chunk of 6061 aluminum $34.00 EA.
Ergonomically designed for maximum grip in tight situations
Fits Tranfercases 67-79 with 2wd option
14 ENG-ACC-701 Made from a solid chunk of 6061 Aluminum $34.00 EA.
Triple chromed for maximum corrosion protection
Fits stock manual and aftermarket shifters
Shifter handle ergonomically made to fit a tight grip
(please specify thread style)
15 ENG-ACC-702 Made from a solid chunk of 6061 aluminum $34.00 EA.
Fits Tranfercases 80-86 cj and 1980 scout
16 ENG-ACC-703 Made from a solid chunk of 6061 aluminum $34.00 EA.
Fits floor mounted standard shifter and aftermarket automatic shifters
Can be used for slap-stick style shifters
(Please include thread type)
17 ENG-AMC-609 Replacement oil pan Fits AMC V8 67-91 $89.99 EA
Oil Pan Comes Painted black with drain plug and internal baffle
Mudrat the meannie 🙁:
