OK,
Here's an
since I've finally been able to get back to work on the CJ, SOA project.
Rear perch welded in, but not braced
I think I may have a problem here?? The tie rod is only 1/4 in above the spring on the P-side, but about 1" on the drivers side? And I need a new drop pittman that will fit the 3/4" Heim joint :shock:
WOOHOO! FINALLY SITTING ON RUBBER!!!
(but I had to take the left front back off or I couldn't get in/out of the shop :oops: )
HI-steer setup drivers-side (not bolted down)
HI-steer setup pssngr-side (not bolted down)
Me and the Jeep in my Way to small shop
Closer-up proof of the dastardly deed, done dirt cheap... :wink:
OK, time for lunch - then, it's back to the shop with me ...
