TommyD wroteDoes anyone out there have a diagram or closeup picture of the heater linkage?
It's the one that connects to the heater/vent cable.
After replacing the dash and broken cables, I found out that the previous owner did not put it together correctly and and didn't connect the cable, so I didn't realize it until now.
AAAAaahhhhhh yes .... I went thru the same thing with an 87 YJ. I'm digging up a disk right now to see if I can send the DWG. That was the only way I could sort it out. The Jeep Tech Manual (or Haynes and Chiltons) doesn't do a good job at all so the Jeep Parts book told me the color of the plastic bits on the ends of the cable were the only way to do it. But I don't see any colors listed for 81's.
My disk only goes back to 81 and it's all PDF files (ACROBAT) but figures 24-200, 24-300, 24-900, 24-1000 and 24-1300 (air conditioning) are applicable. I'd send it to you but I can't break those out of the 36.8Meg file. My suggestion is to go to the stealership and see if they can print them off the disk/fiche for you.
The other option is I print them, re-scna them and see if they are legible in an e-mail attachment. Inprder to get the fine print, they may be rather large files 2-3meg each.
Pat
