Personally I think you can get a better grind then what you're lookin' at with that Howard cam .
Might check out Lunati and Reed:
http://www.lunaticams.com/Camshafts/AMC1.html These are box cams, but they can do a custom grind to better match the longer 401 stroke.
http://www.reedcams.com/cams.htm
As far as the anti-walk button, that's not something you should need unless your cam was incorrectly ground or it is a roller cam. A correctly ground hyraulic cam will have a taper built into it that keeps the cam in position. When your read of cam walk and gear crash in an AMC it's because the cam was improperly ground, it will typically happen to a fresh motor.
Here are some more cam links:
http://www.powermechanics.com/camlinks.html
Here's your man for a cam consult:
http://www.harveycrane.com/
The problem I see with going with a "box" cam is that you get the same cam that is ground for a 360... which isn't going to make the most out of your 401 with the longer stroke. Having someone very familiar with AMC engines, like Reed, grind a cam for your specific engine will make every difference in what you are trying to accomplish.
The guy building cams at Lunati is supposed to be a hot dog so I wouldn't hesitate to give them a call.
